Image blurred in application UI
Hi Team,
I’m developing an application in the colibri iMX6DL board. This was powered by the OS of Yocto (Dunfell) - wayland.
In this, we are developing an application in C++ with UI and image supported components. We are facing some blur effect while executing in the board which I had attached in this mail. This is not a continuous effect. We can monitor at sometimes frequently. Even this we can’t predict at the particular function in the UI. Sometimes it appears and sometimes it is not with the same functionality. Due to this it was very critical to execute that application. Kindly give us the right solution to fix this issue.
Please make this as high priority as possible.
With regards
Kesavan T
