I2S master does not generate master clock on verdin imx8m-plus
Objective
Connect 4 mono audio devices to the iMX using the codec CS4234 (i2s)
Description
The audio codec requires a master clock and as i2s master, the iMX should generate it. A custom device tree overlay is applied to configure i2s (see below), but there is no clock signal at the configured pin. The file imx8mp-verdin-dev.dtsi was used as reference.
dmesg contains the error fsl-aud2htx 30cb0000.aud2htx: failed to pcm register 5 times.
dmesg.log (32.4 KB)
/dts-v1/;
/plugin/;
#include <dt-bindings/clock/imx8mp-clock.h>
#include "imx8mp-pinfunc.h"
    compatible = "toradex,verdin-imx8mp";
    sound {
        compatible = "simple-audio-card";
        simple-audio-card,bitclock-master = <&codec_dai>;
        simple-audio-card,format = "i2s";
        simple-audio-card,frame-master = <&codec_dai>;
        simple-audio-card,mclk-fs = <256>;
        simple-audio-card,name = "radios";
        simple-audio-card,routing =
            "Line Out", "R1OUT",
            "Line Out", "R2OUT",
            "Line Out", "R3OUT",
            "Line Out", "R4OUT",
            "R1IN", "Line In",
            "R2IN", "Line In",
            "R3IN", "Line In",
            "R4IN", "Line In";
        simple-audio-card,widgets =
            "Line Out", "Line Out",
            "Line", "Line In";
        codec_dai: simple-audio-card,codec {
            clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIOMIX_SAI1_MCLK1>;
            sound-dai = <&cs4234>;
        simple-audio-card,cpu {
            sound-dai = <&sai1>;
/* Verdin I2C_1 */
&i2c4 {
	/* Audio Codec */
	cs4234: audio-codec@10 {
		compatible = "cirrus,cs4234";
		reg = <0x10>;
        VA-supply = <&reg_5p0v>;
        VL-supply = <&reg_1p8v>;
		pinctrl-names = "default";
		pinctrl-0 = <&pinctrl_sai1>;
		#sound-dai-cells = <0>;
/* Verdin I2S_1 */
&sai1 {
	assigned-clocks = <&clk IMX8MP_CLK_SAI1>;
	assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
	assigned-clock-rates = <24576000>;
	fsl,sai-mclk-direction-output;
    fsl,sai-synchronous-rx;
tcbuild.yaml (757 Bytes)
The codec is connected to the I2S_1, pins 11 to 15 of X19 (SODIMM Pins 30, 32, 34, 36, 38) and I2C_1, pins 10 and 11 of X10 (SODIMM Pins 12 and 14). All I2S pins just keep having ground level.
Device
Software summary
Bootloader: U-Boot
Kernel version: 6.6.54-7.1.0-g3493ccd66900 #1-Torizon SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/126e49fd181914e3dee90ccea67ccf14d4897990e0e223ebde4654af4f5fd774/0
Distro name: NAME=“Torizon OS”
Distro version: VERSION_ID=7.1.0-build.4
Distro variant: VARIANT=“Docker”
Hostname: verdin-imx8mp-15010410
Hardware info
HW model: Toradex Verdin iMX8M Plus on Mallow Board
Toradex version: 0065 V1.1A
Serial number: 15010410
Processor arch: aarch64
To address the issue of the I2S master clock not being generated on your Verdin iMX8M Plus, let’s explore a few key areas:
  1. Device Tree Configuration: Ensure your device tree overlay is correctly setting up the I2S interface and master clock. The assigned-clocks and assigned-clock-parents for the sai1 node appear to be set to use IMX8MP_AUDIO_PLL1_OUT, which is correct. However, verify that the assigned-clock-rates value of 24576000 Hz is suitable for your application and matches the CS4234 codec’s requirements.
  2. Master Clock Output: The fsl,sai-mclk-direction-output property is set to output the master clock, which is correct. Double-check the physical connections to ensure the correct pin is used for the master clock output and that there are no hardware issues.
  3. Error Message in dmesg: The error fsl-aud2htx 30cb0000.aud2htx: failed to pcm register indicates a potential issue with the PCM interface registration. This might be due to a misconfiguration in the device tree or a missing driver. Ensure the CS4234 codec driver is loaded and compatible with your kernel version.
  4. Kernel and Driver Compatibility: Confirm that your kernel version supports the CS4234 codec and the I2S configuration. Sometimes, updating the kernel or applying specific patches may be necessary.
  5. Clock Source and Routing: Verify that the clock source is correctly routed and enabled in the system. Check the clock tree configuration in the kernel to ensure the clock source is active and properly routed to the I2S interface.
  6. Testing and Debugging: Use tools like i2cdetect to verify I2C communication with the codec. Additionally, check the ALSA configuration to ensure the audio interface is correctly set up.
I hope these steps help you resolve the issue. If you have further questions, feel free to ask.
Toradex AI Assistant
https://community.nxp.com/t5/i-MX-Processors/iMX8M-SAI-Master-Clock-quot-Skipping-quot/m-p/902615
IMX8MP Verdin on Mallow carrier board.
Hi @niiigoo!
I saw that the audio codec CS4234 driver is not enabled in the kernel. You must enable it and, assuming that your overlay is right, it should work.
To enable the driver, you can use Yocto and add a fragment to our meta-layer. Please refer to the NXP fragments in our meta-layer as an example.
In your case, you can add a file called, for example, codec.cfg in the same folder as the other fragments (linux-toradex-6.6-2.1.x) with the adjustments you want to do. As far as I check, the config responsible for this driver is called CONFIG_SND_SOC_CS4234, so you have to write in this file as follows:
CONFIG_SND_SOC_CS4234=y
After that, you must build the image and your fragment will be merged.
Feel free to ask if you face any doubts or issues.
Best regards.
Lucas Azeituno
