I2c Implementation
I want to check i2c…how can i check with colibri eval board. And If i want to implement a code in eclipse then Is there any library file available for that?
I am not able to open https://developer.toradex.com/knowledge-base/i2c-(linux). It gives page not founr error. I will look at that 2nd link.
alt text
I am getting thi s kind of output while i am writing command to detect devices for i2c-0.
That just means at most of them I2C addresses nobody is answering. Either configure the kernel messages to no longer show those messages on the console or login via e.g. SSH and run your command from there.
I’d recommend you to start with this article - https://developer.toradex.com/knowledge-base/i2c-(linux)
For more details please see dev-interface « i2c « Documentation - linux-toradex.git - Linux kernel for Apalis, Colibri and Verdin modules and check all other documents at Documentation/i2c
I fixed the links. In @alex.tx’ the closing parenthesis was missing and yours had an additional dot at the end.
