Hello there;
I’m implementing a driver for a IMX678 sensor that is connected to the i.MX95 Toradex Verdin Mallow-dev carrier. Currently, I have a functional driver that is able to capture raw images, and I can output the images using the ISI pipeline handler (simple raw capture). A simple pipeline using libCamera utils can capture from the sensor fine:
cam --camera 1 --stream width=1920,height=1080,role=raw --capture=10 --file=/tmp/frames.raw
When I try to use the neo-ISP handler and the ISP path, the capture hangs. To enable the neo-ISP, I’m using libCamera along with the necessary imx678_camera_helper file and the imx678.yaml ISP configuration file. The pipeline is currently using the IPA NXP default algorithms, and I was following the NXP sensor porting guide to implement all the pieces that are required for the sensor to work.
Since I’m building the BSP using Yocto and the Toradex BSP 7.6.1, the kernel comes from linux-toradex 6.6.2.2.x-imx, which is based on a linux 6.6.138. I found the libCamera lf-6.6.52.2.2.2 compatible. I couldn’t find any recommendation from Toradex so this is a best-fit assumption.
During debugging, I found no ISP interruptions are fired while capturing, leading to the pipe getting stuck trying to process buffers. I confirmed the sensor delivers frames, and libCamera moves those to the ISP input, but no further processing was detected.
My board is V1.0C, which may indicate a silicon update with respect to other boards, and potential kernel-hw description changes that may affect ISP.
I would like to ask the following questions:
- Do you have references of i.MX95 Verdin boards capturing video and using the ISP module? I may benefit from implementation references to figure out what is missing.
- Is the libCamera version described above the correct one according the hardware I have?
- Is there any ISP configuration you recommend to enable capturing through ISP path?
- Is my board V1.0C revision suggestion updates in the kernel / ISP driver side that maybe I’m missing in the documentation?
I’m attaching the full “tdx-info“ of my board.
Thanks;
Daniel.
Software summary
Bootloader: U-Boot
Kernel version: 6.6.138-7.6.1-devel #1 SMP PREEMPT Fri May 8 12:46:27 UTC 2026
Kernel command line: root=PARTUUID=f4af52a9-02 ro rootwait console=tty1 console=ttyLP2,115200
Distro name: NAME=“TDX Wayland with XWayland”
Distro version: VERSION_ID=7.6.1-devel-20260618213900-build.0
Distro variant: -
Hostname: verdin-imx95-08828804
Hardware info
HW model: Toradex Verdin iMX95 WB on Verdin Development Board
Toradex version: 0089 V1.0C
Serial number: 08828804
Processor arch: aarch64
