Just curious if anybody has gotten anything for wxWidgets to compile and run on the new imx8m-plus?
You can’t even install the required support libraries due to the X11 shenanigans.
It might be buildable under a raw Bullseye.
I gave up and moved to another product.
Do you have a specific Yocto config to exhibit this issue? I was able to build the wxwidgets recipe by explicitly setting PACKAGECONFIG to “qt”.
Drew
I was not in yocto. In container. More specifically, nothing GUI related can be built in Wayland container. If you want to use a tried and true library, you simply cannot install the build dependencies.
Thank you for your assistance Drew, but we’ve moved on. There is no point to digging into this further.
