Starting with the ‘colibri-imx6_lxde-image-tezi_2.7-20180104.tar’, I’m able to flash my colibri V1.0A using the Toradex Easy Installer (colibri-imx6_toradexeasyinstaller_1.4-20180403). So far so good.
Next I started to build a U-Boot from sources, following the steps outlined in “Build U-Boot and Linux Kernel from Source Code”. After the succesfull build of the u-boot, I copied the SPL and u-boot.img from my build directory into the Tezi image directory, and also adjusted the image.json (u-boot.img instead of u-boot.imx) file.
Next I placed the contents of the Tezi image directory on an USB stick. The Colibri module has the tezi application up and running (no network cable attached), and the USB stick is detected. Next I flash the images from the USB stick to my module, everthing seems to be working fine.
Next step is to restart the module (or power cycle), the u-boot is started but somehow fails to load the linux kernel as it seems to be looking for a zImage (There’s only a uImage present).
What is going wrong, I must have missed something?
Below is the output at the serial port: link text
Kind Regards,
Alberto
