Hi Guys,
I want to use all 4 SPI channels and configure SPI data as interrupt.
I modified below code and can see:
&ecspi3 {
mcp2515: can@0 {
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_can_int>;
reg = <0>;
clocks = <&clk16m>;
interrupt-parent = <&gpio5>;
interrupts = <2 IRQ_TYPE_EDGE_FALLING>;
spi-max-frequency = <10000000>;
status = "disabled";
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <23000000>;
root@colibri-imx7-emmc:/tmp# dmesg | grep spi
[ 1.115033] spi_imx 30840000.ecspi: dma setup error -19, use pio
[ 1.124327] spi_imx 30840000.ecspi: probed
root@colibri-imx7-emmc:/tmp# ls /dev/spi*
/dev/spidev2.0
I want to know:
- How to enable other 3 SPI drivers
- Where to find details on HW pins or which pins shall I use to connect slave device
HI @neeraj.verma
What exactly do you mean with configure SPI data as interrupt? You can enable the interrupt on the chip select line.
You just to do the create the SPI nodes and do the correct muxing of the Pins as described here.
Please check the datasheet of the module.
Hi @jaski.tx
Thanks for the reply. Can I use CS as interrupt as well (one pin having two functions output and interrupt)?
I only see one instance of spi3, how do I create another:
Ex: spidev1: spidev@1
/* Colibri SPI */
&ecspi3 {
fsl,spi-num-chipselects = <1>;
cs-gpios = <&gpio4 11 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pinctrl_ecspi3 &pinctrl_ecspi3_cs>;
I really don’t see which pins I should use for another SPI node.
Hi @neeraj.verma
You are welcome.
CS is an output and interrupt an output. So I don’t think, this will be possible, but you can connect the chip select to another SODIMM Pin over the carrier board and the other SODIMM Pin can be defined as Interrupt.
For having more spi Node, first you need to change in the escpi3 node the following parameters in the devicetree on the module layer:
number of chipselects,
Gpios to use for chipselect
change pinctrl-0 referencing node to do the correct pinmuxing of the chip select pins
/* Colibri SPI */
&ecspi3 {
pinctrl-names = “default”;
On carrier board layer, you need to define the differents spidev3.x under ecspi3 and change the property reg = , where x comes from the chipselect used.
Hi Jaski (@jaski.tx ),
I just probed SODIMM_86 pin on board while reading SPI, I don’t see CS is LOW. (first step). Could you please help me on this to understand what is wrong?
&ecspi3 {
mcp2515: can@0 {
reg = <0>;
clocks = <&clk16m>;
spidev0: spidev@0 {
reg = <0>;
&ecspi3 {
pinctrl_ecspi3: ecspi3-grp {
fsl,pins = <
MX7D_PAD_I2C1_SCL__ECSPI3_MISO 0x2
MX7D_PAD_I2C1_SDA__ECSPI3_MOSI 0x2
MX7D_PAD_I2C2_SCL__ECSPI3_SCLK 0x2
pinctrl_ecspi3_cs: ecspi3-cs-grp {
fsl,pins = <
MX7D_PAD_I2C2_SDA__GPIO4_IO11 0x14
Attaching dmesg log and SPI code for you to have a quick look.
link text
hi @neeraj.verma
You are having IoMux errors in the dmesg log. Could you correct them and check again, if SPI is working.
Thanks @jaski.tx for pointing out.
actually that pin is used for UARTxx, I used another pin for CS and my code works now.
Sharing correct code for users:
&ecspi3 {
mcp2515: can@0 {
reg = <0>;
clocks = <&clk16m>;
spidev0: spidev@0 {
reg = <0>;
/*spi-max-frequency = <23000000>;*/
&ecspi3 {
status = “okay”;
fsl,spi-num-chipselects = <2>;
cs-gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>;
fsl,pins = <
MX7D_PAD_SD1_DATA3__GPIO5_IO8 0x14
fsl,pins = <
