Hello world,
I’m trying to use eclipse and debug GTK application, in
IMX6DL, now I’m able to cross compile the application, now I want to debug the application wirelessly so what is the way to do that?
While wirless debugging GTK application from eclipse,
I’m getting this error
root@colibri-imx6-10934338:~# /home/root/hello_world;exit
(hello_world:1164): Gtk-e[1;33mWARNINGe[0m **: e[34m12:08:00.777e[0m: cannot open display: :0.0
I’m using ubuntu 20.04.
regards,
Nolan
Hi @Nolan_Maverick ,
Can you elaborate a bit more about your setup?
Are you using a custom carrier board?
Which version of the BSP are you using?
Kevin
Hi @kevin.tx ,
I’m using Colibri Evaluation Board,
and I’m using BSP 5, I followed this link Build a Reference Image with Yocto Project/OpenEmbedded | Toradex Developer Center
exactly to generate image, I used toradex reference multimedia image
please ask if any more information is needed?
warm regards,
Nolan
Hello @kevin.tx
do you need anymore information?
Hello @Nolan_Maverick,
Did you follow this article from our developer web-page for setting the remote debugging options on eclipse?
Your error message looks more like a problem with the wrong settings on X11 forwarding. Could you please try the following:
Go to the file /etc/ssh/sshd_config
on your colibri module and enable x11 forwarding as: X11forwarding yes
Go to the debugging configuration → “Commands to set before execution” on Eclipse and add the command: export DISPLAY=":0.0"
Please check if it works after the second step. If not try to set the Display manually from the command line of the host machine (your Ubuntu machine) by running the command:
export DISPLAY="127.0.0.1:10.0"
Let me know if that solves your problem. Happy debugging
Hi @rudhi.tx
thanks for your suggestion, I don’t have any ssh folder under /etc directory
and when I tried both
- export DISPLAY=“127.0.0.1:10.0”
But I’m getting error
root@colibri-imx6-10909128:~# export DISPLAY="127.0.0.1:0"root@colibri-imx6-10909128:~# ./hello_world
(hello_world:684): Gtk-WARNING **: 12:46:16.358: cannot open display: 127.0.0.1:0
warm regards,
Nolan
Hello @rudhi.tx and @kevin.tx ,
Thanks for your suggestions, previously I was using dropbear, but now I’m using openssh, through which I’m able to display GTK application wirelessly.
Warm Regards,
Nolan
Hi @Nolan_Maverick,
Thanks for the update and glad to hear that it works for you now
