How to use DS-MPE-CAN2L on apalis-tk1?
How to use DS-MPE-CAN2L (PCIe MiniCard Expansion Module with Dual CAN 2.0 Ports)
on apalis-tk1 on eagle baseboard (Rugged 3.5" Baseboard for ARM Computer-on-Modules)
using mPCIe ?
eagleBB is running on angstrom linux 3.10.40.
problem is when mounted on the board on mpcie the module is not getting detected.
please provide lspci and dmesg outputs.
link text
It looks like it’s detected:
03:00.0 Memory controller: Xilinx Corporation Device 0505
compare lspci output with and without that card, and you’ll
