How to use customized fstab in Colibri imx6ull
I want to change fstab in Yocto recipe.
Please tell me the procedure. Or provide a sample recipe.
Hi @max.tx @jaski.tx , do you know where do we have the base-files recipe of the fstab file in our BSP 5 for Colibri iMX6ULL?
I was following this answer: https://stackoverflow.com/a/43284502
I couldn’t find it in our repo.
base-files recipe does not include fstab.
So I need to add and modify the rootfs image in the image recipe.
I understood this.
As a test, I created base-files_%.bbappend.
(Refer to the URL for the contents)
After Bitbake, the fstab of the following packages was updated.
(Colibri-iMX6ULL_Reference-Multimedia-Image.rootfs.tar.xz)
Thanks,
Dear @C.T, the fstab file is found here:
http://git.toradex.com/cgit/meta-toradex-demos.git/tree/recipes-core/base-files/base-files/fstab?h=dunfell-5.x.y
You should be able to edit this file in your Yocto environment.
Kind regards,
Alvaro.
