How to set static IP in default image?
How to set static IP for apalis imx6Q linux manually?
I believe you should be able to use systemd-networkd to configure a static ip. This process is detailed in this article: https://developer.toradex.com/knowledge-base/ethernet-network-(linux)#systemdnetworkd .
