How to set dts file for enabling relay on off?
I am using now sodimm_133.
so gpioinfo is below:
gpiochip1 - 32 lines:
line 0: “SODIMM_111” unused input active-high
line 1: “SODIMM_113” unused input active-high
line 2: “SODIMM_115” unused input active-high
line 3: “SODIMM_117” unused input active-high
line 4: “SODIMM_119” unused input active-high
line 5: “SODIMM_121” unused input active-high
line 6: “SODIMM_123” unused input active-high
line 7: “SODIMM_125” unused input active-high
line 8: “SODIMM_91” unused input active-high
line 9: “SODIMM_89” unused input active-high
line 10: “SODIMM_105” unused input active-high
line 11: “SODIMM_152” unused input active-high
line 12: “SODIMM_150” unused input active-high
line 13: “SODIMM_95” unused input active-high
line 14: “SODIMM_126” unused input active-high
line 15: “SODIMM_107” unused input active-high
line 16: “SODIMM_114” unused input active-high
line 17: “SODIMM_116” unused input active-high
line 18: “SODIMM_118” unused input active-high
line 19: “SODIMM_120” unused input active-high
line 20: “SODIMM_122” unused input active-high
line 21: “SODIMM_124” unused input active-high
line 22: “SODIMM_127” unused input active-high
line 23: “SODIMM_130” unused input active-high
line 24: “SODIMM_132” unused input active-high
line 25: “SODIMM_134” unused input active-high
line 26: “SODIMM_133” “relay_led_sodimm_133” output active-high [used]
@Uday10122 please check above output and help me solve this problem. when i check voltage so its showing 0.6 and 0.7 even when my relay is off.
