Hello Vishal,
Thank you for providing detailed information about your setup and the issue. The error you’re facing while building the GPIO C example is likely due to missing GPIO development dependencies—specifically, the libgpiod development headers and libraries.
Here’s how you can resolve the error and build the GPIO C example for your i.MX8MP (arm64) module:
1. Update torizonPackages.json
Add the required GPIO development libraries to your torizonPackages.json as below:
"deps": [
"libgpiod2"
"devDeps": [
"libgpiod-dev"
This ensures libgpiod and its development files are available in your container.
Learn more: C GPIO application sample, Toradex Docs
2. Update the Makefile
Ensure your Makefile links against the gpiod library:
- LDFLAGS :=
+ LDFLAGS := -lgpiod
This step allows proper linkage for GPIO functions used in your application.
3. Rebuild the Development Container
Once you’ve updated torizonPackages.json, rebuild the development container.
- In VS Code: Open the Command Palette and run Torizon: Rebuild Container.
- Alternatively, run the
check-depstask.
This ensures the new dependencies are installed in your build environment.
See details: Community Reference
4. Confirm Device Access
Make sure your docker-compose.yml gives the container access to the required GPIO device:
devices:
- "/dev/gpiochip0"
Summary
- Add
libgpiod2andlibgpiod-devtotorizonPackages.json - Link the binary with
-lgpiodin the Makefile. - Rebuild the container for dependencies to take effect.
- Confirm
/dev/gpiochip0access in yourdocker-compose.yml.
These steps should resolve the “gpiod.h: No such file” and allow you to build and run the GPIO C example on your i.MX8MP.
Let me know if you need further clarification or run into any other issues!
