Greetings @f.mazur,
Actually your overall idea of modifying the weston.ini
file is correct, though there is a better way to do it then what you did.
For context when we build our containers we include a default weston.ini
. This can be found here: debian-docker-images/weston at buster · toradex/debian-docker-images · GitHub
This gets copied to the usual spot in the container at /etc/xdg/weston/weston.ini
So what you should do is overwrite this file when you start a weston-based container. You can do this simply via a bindmount. For example if you have your weston.ini
in /home/torizon
, then by adding the following to docker run
: -v /home/torizon/weston.ini:/etc/xdg/weston/weston.ini
This option will take your weston.ini
and overwrite the weston.ini
that the container shipped with.
Alternatively you can also just rebuild the container with your weston.ini
. That way you have your own variant on our weston container. Either of these options would be fine depending on your needs.
