How to resize PCIE window on IMX8QM?
I am trying to resize the PCIE windows (in file imx8qm-ss-hsio.dtsi), so that, PCIEA becomes larger with 256MB MEM window plus default IO window, while shortening PCIEB in order to release space for PCIEA, like so:
pciea: pcie@0x5f000000 {
    reg = <0x5f000000 0x10000>, /* Controller reg */
          <0x70000000 0x80000>, /* PCI cfg space */
	      <0x5f080000 0xf0000>; /* lpcg, csr, msic, gpio */
   reg-names = "dbi", "config", "hsio";
   ranges = <0x81000000 0 0x00000000 0x70080000 0 0x00010000 /* downstream I/O */
	         0x82000000 0 0x60000000 0x60000000 0 0x10000000>; /* non-prefetchable memory */
and PCIEB to:
pcieb: pcie@0x5f010000 {
   reg = <0x5f010000 0x10000>, /* Controller reg */
	     <0x7ff00000 0x80000>, /* PCI cfg space */
   ranges = <0x81000000 0 0x00000000 0x7ff80000 0 0x00010000 /* downstream I/O */
	       0x82000000 0 0x71000000 0x71000000 0 0x0ef00000>; /* non-prefetchable memory */
But when I do this, the Linux kernel is not able to setup the windows and the WiFI card is not detected on PCIEB, nor any card on PCIEA.
Even if I simply modify PCIEB leaving PCIEA unchanged, is enough for the PCIEB window not to be properly configured.
What am I doing wrong? How can I resize the PCIE windows?
Greetings @CoreRasurae,
Unfortunately I’m afraid we still didn’t tweak much with the default PCIe window settings that come from NXP.
Since it’s a more specific topic, I suggest you to contact NXP directly via their community on this matter.
