I was in the U-Boot terminal trying to install easy installer and was following the steps in link. But doing I ran across the error
Error: “distro_bootcmd” not defined
And doing so I changed the env variable and now I cannot do a normal boot either.
Hi @AnandhaKrishnanH and welcome to the Toradex Community!
Could you provide the Software version of your module?
You can reset the U-Boot Environment by doing the following.
env default -a
saveenv
