What is the procedure to remove unneeded packages from rootfs in a OpenEmbedded image?
And what I have to do in case of packages dependencies?
Dear @gvnn,
Greetings and Thank you for contacting Toradex Community!
You can remove the packages using IMAGE_INSTALL_remove += "<Package>"
. All the dependent packages associated with the package will be removed; unless a package is also associated with another remaining package. In that case, the dependent package will remain.
Janani.
