Is there an example program to query the running BSP version, without using the Toradex libraries?
You can use the following code to query the BSP version:
#include "windows.h"
// BSP Version Structure (old style)
typedef struct {
DWORD ID;
DWORD Maj;
DWORD Min;
} BSPVER;
// BSP Version structure
typedef struct {
WORD BspId;
WORD FormId;
DWORD Maj;
WORD Min;
WORD Beta;
DWORD LoaderMaj;
WORD LoaderMin;
WORD LoaderBeta;
} BSPVEREX;
// IOCTL related definitions
#define FILE_DEVICE_HAL 0x00000101
#define METHOD_BUFFERED 0
#define FILE_ANY_ACCESS 0
#define CTL_CODE( DeviceType, Function, Method, Access ) (((DeviceType) << 16) | ((Access) << 14) | ((Function) << 2) | (Method))
#define IOCTL_HAL_GET_BSP_VER (DWORD)(CTL_CODE(FILE_DEVICE_HAL, 2051, METHOD_BUFFERED, FILE_ANY_ACCESS))
// function prototype to execute the IOCTL
BOOL KernelIoControl(DWORD dwIoControlCode, LPVOID lpInBuf, DWORD nInBufSize, LPVOID lpOutBuf, DWORD nOutBufSize, LPDWORD lpBytesReturned);
int _tmain(int argc, _TCHAR* argv[])
BSPVEREX bspVer = {0};
if(!KernelIoControl(IOCTL_HAL_GET_BSP_VER, NULL, 0, &bspVer, sizeof(BSPVEREX), NULL))
{ // Try with the old size
KernelIoControl(IOCTL_HAL_GET_BSP_VER, NULL, 0, &bspVer, sizeof(BSPVER), NULL);
The call using BSPVER
works on all BSPs, the call using BSPVEREX
only is supported on newer BSPs.
Some of the definitions are used for all IOCTL calls and are taken from general help files. However, I included the definitions here to avoid dependencies from other header files.
how to solve the link error:
error LNK2019: unresolved external symbol "int __cdecl KernelIoControl(unsigned long,void *,unsigned long,void *,unsigned long,unsigned long *)" (?KernelIoControl@@YAHKPAXK0KPAK@Z) referenced in function wmain
change
to
extern "C" BOOL KernelIoControl(DWORD dwIoControlCode, LPVOID lpInBuf, DWORD nInBufSize, LPVOID lpOutBuf, DWORD nOutBufSize, LPDWORD lpBytesReturned);
You can read why here → What is the effect of extern "C" in C++? - Stack Overflow
