How to port QT Application to Linux Toradex Version 5.0.0 in Apalis iMX6Q
How to port QT Application to Toradex Version 5.0.0 in Linux
Dear Manualex,
This depends on various factor below are the few things you need to take care
  • Which version of qt you have used and changes you need to do accordingly.
  • Check which backend for display you are using and modify accordingly. With BSP 5 you have option to use wayland.
  • Check for API which are dropped from older to new qt version and update same in your application.
  • Compile custom Linux image with qt support. You can take reference from our multimedia reference image.
  • Check this link for release notes, this will give idea about things which changed from older version.
Let me know if you have any queries.
Ritesh Kumar
