rafagcf
1
Hi guys! I’m trying to install a older version of WEC 2013 but I’m having problems to do it with the USB.
So I started to find the Json of the old WEC versions
In TEZI there is the “feeds” menu that u can insert a list
Do you know what is the URL of the list that has the old WEC?
alex.tx
2
What exactly version you are looking for?
rafagcf
3
Version 1.3.1
or version 1.3
alex.tx
4
rafagcf
5
Yes, I know. But i wanted to download directly from TEZI, because it is not working with the USB
alex.tx
6
it should work. Did you unpack downloaded zip file to USB drive or just copied it as is?
alex.tx
8
It sounds strange. Never had problem with using USB drive with Toradex Easy Installer. Could you try SD card instead?
