We want to have USB printer support in our application.
We are using HP LaserJet P1106 USB printer.
We would like to know How to install HPLIP on Collibri iMX7 board.
We have installed CUPS on board but there is one issue (Shown in attached image).
We are using Embedded linux open embedded layer.
Please help!
Pradeep Pol
Hi @eklavya19
Could you provide the version of the hardware (including carrier board) and software ( uname -a
) of your module?
Could you share the dmesg log in a text file and the output of lsusb
when the printer is connected?
Hi Jaski,
Thanks for the reply!
Software & Hardware version
We are using collibri iMX7 256 mb som (v1.1C) with VIOLA Plus (v1.2B)
root@colibri-imx7:~# uname -a
Linux colibri-imx7 4.9.166-2.8.6+gd899927 #1 SMP Sat Jun 1 15:31:52 UTC 2019 armv7l GNU/Linux
lsusb output when printer is connected
root@colibri-imx7:~# lsusb
Bus 001 Device 003: ID 03f0:002a Hewlett-Packard LaserJet P1102
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg when printer connected
[ 2623.864591] usb 1-1: new high-speed USB device number 3 using ci_hdrc
Pradeep Pol
Dear @eklavya19 ,
Thank you for contacting Toradex Community!
Could you please verify if your CONFIG_USB_PRINTER in your .config file is enabled?
If not, could you please ENABLE this setting and re-compile your colibri_imx7_defconfig by using make colibri_imx7_defconfig
. Here is the link for Kernel re-compilation reference.
As you are using CUPS, you might also want to install the CUPS package using opkg update && opkg install cups
Thanks and Regards,
Janani.
