Thanks for warm encouragement. I changed my plan as we discussed. I downloaded the rocko linux source files to my localhost and will do devicetree customization and kernel configuration locally. and then cross compile my image. and update som via easy installer.
for wvdial and gammu as you suggested i typed “bitbake wvdial” and “bitbake gammu” it seems its been builded.
wvdial_1.61-r0_armv7at2hf-neon.ipk , gammu_1.32.0-r0_armv7ahf-neon.ipk
files are under deploy/ipk/armv7at2hf-neon/ directory.
there is also wvdial-dbg_1.61-r0_armv7at2hf-neon.ipk and wvdial-dev_1.61-r0_armv7at2hf-neon.ipk and wvdial-doc_1.61-r0_armv7at2hf-neon.ipk files related with wvdial. which file shall i use? same goes for gammu.
You can install these packages with opkg install packagename after doing opkg update. If the packages are not found, then you need to build the needed packages using bitbake and copy them to the SoM.
I am trying to install wvdial to my som but it seems it needs dependencies. I started to install them and
libwvutils4.6 needs libwvstreams-extras and libwvstreams-extras needs libwvutils4.6 to install. I am confused.
Any suggestions?
Reagrds
libwvutils4.6 needs libwvstreams-extras and libwvstreams-extras needs libwvutils4.6. it is a deadlock. Two packages needed eachother. any suggestions? Regards.
I managed to use virtual/kernel and did menuconfig on openembedded.
(bitbake -f -c unpack virtual/kernel) (bitbake -f -c menuconfig virtual/kernel). I changed settings on menuconfig and saved them. will those changes apply to the kernel zimage if i build it with bitbake ?
and second question will it be appropriate if i modify device tree outside yocto and get the .dtb file and update my som ?
best regards.
