Hello, I have a angstrom-qt5-x11-image running on TK1, I am using cmake for installing a qt application, but apparently cmake requires development versions of qt, So anyone can tell me how to get qt5 dev packages in TK1.
Qt5 related error
-- The following REQUIRED packages could NOT be located on your system.
-- You must install these packages before continuing.
* Qt (5.0.0 or higher) <http://qt-project.org/>
Required for building everything
* QtQuick2 (QtQuick) (5.0.0 or higher) <http://qt-project.org/>
Required for building QtQuick2 support
* QtQml (5.0.0 or higher) <http://qt-project.org/>
Full cmake output
root@apalis-tk1:~/qt-gstreamer-1.2.0/build# cmake .. -DCMAKE_INSTALL_PREFIX=/home/root/qt-gstreamer-1.2.0/install -DQT_VERSION=5
-- The C compiler identification is GNU 7.3.0
-- The CXX compiler identification is GNU 7.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Using Qt5 (min: 5.0.0)
CMake Warning at cmake/modules/FindQt4or5.cmake:69 (find_package):
By not providing "FindQt5Core.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Core", but
CMake did not find one.
Could not find a package configuration file provided by "Qt5Core"
(requested version 5.0.0) with any of the following names:
Qt5CoreConfig.cmake
qt5core-config.cmake
Add the installation prefix of "Qt5Core" to CMAKE_PREFIX_PATH or set
"Qt5Core_DIR" to a directory containing one of the above files. If
"Qt5Core" provides a separate development package or SDK, be sure it has
been installed.
Call Stack (most recent call first):
CMakeLists.txt:24 (find_package)
By not providing "FindQt5Gui.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Gui", but
Could not find a package configuration file provided by "Qt5Gui" (requested
Qt5GuiConfig.cmake
qt5gui-config.cmake
Add the installation prefix of "Qt5Gui" to CMAKE_PREFIX_PATH or set
"Qt5Gui_DIR" to a directory containing one of the above files. If "Qt5Gui"
provides a separate development package or SDK, be sure it has been
installed.
By not providing "FindQt5Widgets.cmake" in CMAKE_MODULE_PATH this project
has asked CMake to find a package configuration file provided by
"Qt5Widgets", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Widgets"
Qt5WidgetsConfig.cmake
qt5widgets-config.cmake
Add the installation prefix of "Qt5Widgets" to CMAKE_PREFIX_PATH or set
"Qt5Widgets_DIR" to a directory containing one of the above files. If
"Qt5Widgets" provides a separate development package or SDK, be sure it has
been installed.
By not providing "FindQt5OpenGL.cmake" in CMAKE_MODULE_PATH this project
"Qt5OpenGL", but CMake did not find one.
Could not find a package configuration file provided by "Qt5OpenGL"
Qt5OpenGLConfig.cmake
qt5opengl-config.cmake
Add the installation prefix of "Qt5OpenGL" to CMAKE_PREFIX_PATH or set
"Qt5OpenGL_DIR" to a directory containing one of the above files. If
"Qt5OpenGL" provides a separate development package or SDK, be sure it has
been installed.
By not providing "FindQt5Declarative.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"Qt5Declarative", but CMake did not find one.
Could not find a package configuration file provided by "Qt5Declarative"
Qt5DeclarativeConfig.cmake
qt5declarative-config.cmake
Add the installation prefix of "Qt5Declarative" to CMAKE_PREFIX_PATH or set
"Qt5Declarative_DIR" to a directory containing one of the above files. If
"Qt5Declarative" provides a separate development package or SDK, be sure it
has been installed.
By not providing "FindQt5Quick.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Quick",
Could not find a package configuration file provided by "Qt5Quick"
Qt5QuickConfig.cmake
qt5quick-config.cmake
Add the installation prefix of "Qt5Quick" to CMAKE_PREFIX_PATH or set
"Qt5Quick_DIR" to a directory containing one of the above files. If
"Qt5Quick" provides a separate development package or SDK, be sure it has
been installed.
By not providing "FindQt5Qml.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Qml", but
Could not find a package configuration file provided by "Qt5Qml" (requested
Qt5QmlConfig.cmake
qt5qml-config.cmake
Add the installation prefix of "Qt5Qml" to CMAKE_PREFIX_PATH or set
"Qt5Qml_DIR" to a directory containing one of the above files. If "Qt5Qml"
installed.
By not providing "FindQt5Test.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Qt5Test", but
Could not find a package configuration file provided by "Qt5Test"
Qt5TestConfig.cmake
qt5test-config.cmake
Add the installation prefix of "Qt5Test" to CMAKE_PREFIX_PATH or set
"Qt5Test_DIR" to a directory containing one of the above files. If
"Qt5Test" provides a separate development package or SDK, be sure it has
been installed.
-- Could NOT find Qt4or5 (missing: _Qt4or5_FOUND Core Gui Widgets)
-- Boost version: 1.64.0
-- GCC 4.5 or later detected. Enabling C++0x support in QTGSTREAMER_FLAGS.
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'gstreamer-1.0'
-- Found gstreamer-1.0, version 1.12.2
-- Checking for module 'gstreamer-base-1.0'
-- Found gstreamer-base-1.0, version 1.12.2
-- Found GSTREAMER_BASE_LIBRARY: /usr/lib/libgstbase-1.0.so
-- Found GSTREAMER_BASE_INCLUDE_DIR: /usr/include/gstreamer-1.0
-- Found GStreamer: /usr/lib/libgstreamer-1.0.so (Required is at least version "1.0.0")
-- Checking for module 'gstreamer-plugins-base-1.0'
-- Found gstreamer-plugins-base-1.0, version 1.12.2
-- Checking for module 'gstreamer-app-1.0'
-- Found gstreamer-app-1.0, version 1.12.2
-- Found GSTREAMER_APP_LIBRARY: /usr/lib/libgstapp-1.0.so
-- Found GSTREAMER_APP_INCLUDE_DIR: /usr/include/gstreamer-1.0
-- Checking for module 'gstreamer-audio-1.0'
-- Found gstreamer-audio-1.0, version 1.12.2
-- Found GSTREAMER_AUDIO_LIBRARY: /usr/lib/libgstaudio-1.0.so
-- Found GSTREAMER_AUDIO_INCLUDE_DIR: /usr/include/gstreamer-1.0
-- Checking for module 'gstreamer-video-1.0'
-- Found gstreamer-video-1.0, version 1.12.2
-- Found GSTREAMER_VIDEO_LIBRARY: /usr/lib/libgstvideo-1.0.so
-- Found GSTREAMER_VIDEO_INCLUDE_DIR: /usr/include/gstreamer-1.0
-- Checking for module 'gstreamer-pbutils-1.0'
-- Found gstreamer-pbutils-1.0, version 1.12.2
-- Found GSTREAMER_PBUTILS_LIBRARY: /usr/lib/libgstpbutils-1.0.so
-- Found GSTREAMER_PBUTILS_INCLUDE_DIR: /usr/include/gstreamer-1.0
-- Found GStreamerPluginsBase: TRUE (Required is at least version "1.0.0")
-- Checking for module 'glib-2.0'
-- Found glib-2.0, version 2.52.3
-- Found GLIB2: /usr/lib/libglib-2.0.so
-- Checking for module 'gobject-2.0'
-- Found gobject-2.0, version 2.52.3
-- Found GObject: /usr/include/glib-2.0
-- Performing Test USE_OPENGLES
-- Performing Test USE_OPENGLES - Failed
-- Could NOT find OpenGL (missing: OPENGL_gl_LIBRARY OPENGL_INCLUDE_DIR)
CMake Warning (dev) at examples/CMakeLists.txt:13 (get_target_property):
Policy CMP0045 is not set: Error on non-existent target in
get_target_property. Run "cmake --help-policy CMP0045" for policy details.
Use the cmake_policy command to set the policy and suppress this warning.
get_target_property() called with non-existent target "examples_distcheck".
examples/CMakeLists.txt:22 (example_distcheck)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- The following external packages were located on your system.
-- This installation will have the extra features provided by these packages.
* Boost - Required for building QtGLib
* GStreamer - Required to build QtGStreamer
* GStreamer base library - Used for building the qt5videosink element
* GStreamer app library - Required to build QtGStreamerUtils
* GStreamer audio library - Required to build QtGStreamer
* GStreamer video library - Required to build QtGStreamer
* GStreamer pbutils library - Used for building the Discoverer API
* GLib - Required to build QtGLib
* GObject - Required to build QtGLib
-- The following OPTIONAL packages could NOT be located on your system.
-- Consider installing them to enable more features from this software.
* QtOpenGL (5.0.0 or higher) <http://qt-project.org/>
Required for OpenGL acceleration in qtvideosink and QtGStreamerUi
* QtQuick1 (QtDeclarative) (5.0.0 or higher) <http://qt-project.org/>
Required for building QtQuick1 support
* OpenGL <http://www.opengl.org>
Required for OpenGL rendering support in qt5videosink
* Doxygen <http://www.doxygen.org/>
Used to generate the API documentation
CMake Error at cmake/modules/MacroLogFeature.cmake:141 (MESSAGE):
Exiting: Missing Requirements
CMakeLists.txt:202 (macro_display_feature_log)
-- Configuring incomplete, errors occurred!
See also "/home/root/qt-gstreamer-1.2.0/build/CMakeFiles/CMakeOutput.log".
See also "/home/root/qt-gstreamer-1.2.0/build/CMakeFiles/CMakeError.log".
I am also attaching cmake log file.
Thank you.
regards akshay
