I am using this UART connector to connect to the UART1 header on the Ixora evaluation board I am using to start the bootloader menu on my Apalis iMX6 but I have tried everything and nothing seems to actually work. All I get is a garbled mess like the screenshot below.
Things I have tried:
- Different UARTs and different connection combinations.
- Holding down / spamming space bar on each UART connection.
- Attempting to boot in recovery mode by shorting the connector on the Apalis Module. This doesn’t output anything on UART btw.
So I guess my question is mostly: how to I connect the C232HD cable correctly to the UART headers to achieve a proper TTY? I am fairly sure I have connected it correctly and have tried multiple iterations and combinations.
Edit: on UART2 I get this screenshot.
