How to flash several AM62 at same time
Hello Teams Toradex.
I would like to know if an industrial programming solution exists to flash several AM 62 cards at the same time.
Currently I use the Toradex easy installer, but this does not allow me to flash several cards at the same time.
Regards
Marc
To flash multiple cards simultaneously, you will need a carrier board that can accommodate several Verdin modules at once. Currently, we do not offer such a carrier board. However, you can use multiple standard carrier boards (each supporting one SOM) and power them up at the same time. If they have insert an SD card or USB drive containing the image you wish to flash into each board with the autoinstall property set to true, all the modules on these boards will be automatically and simultaneously flashed
