I upgraded kernel from 2.8 to 3.0 and found I am not able to use connmanctl utility to config WiFi USB.
connmanctl enable wifi
Error wifi: Method “SetProperty” with signature “sv” on interface “net.connman.Technology” doesn’t exist
Could you please suggest which tool to use?
Thank you
Neeraj
hi @neeraj.verma
Could you provide the version of the software of your module?
Hi @jaski.tx ,
I was using TP-Link USB WiFi
in kernel 2.8 using connmanctl but it’s not working when I upgraded to 3.0.
did google and found that this utility is not supported in 3.0 (Roadmap BSP 3.0 - Technical Support - Toradex Community)
Could you please help me on this?
You can suggest me which USB WiFi module is supported in 3.0?
Thank you
Neeraj
Hi Neeraj
Connmanctl
is still part of Bsp 3.0.
Which version ( cat /etc/issue
) did you install?
Could you try to install the latest nightly build and check if you still see the issue with your wifi dongle?
Hi @jaski.tx ,
I am sure there is some difference as same wifi dongle works fine with 2.0 but getting error on 3.0.
root@colibri-imx7-emmc:~# cat /etc/issue
TDX X11 2.6-snapshot \n \l
Colibri-iMX7-eMMC_Console-Image 3.0b2 20191202
How can I pull nightly build code?
Thank you
Neeraj
Hi
You need to activate the CI Feeds in the Menu from Toradex Easy Installer.
Hi @jaski.tx ,
Could you please point me link on how to activate CI Feeds?
Thank you
Neeraj
You don’t need any link. Just boot the Toradex Easy Installer and click on the Feeds from the Menu. Then you can activate the CI Feeds.
