I want to use UART2 of VF61 SoC from M4 core, so I need to be sure that WinCE 6 on A5 doesn’t use this peripheral.
Is there any WinCE registry setting where I can completely disable it for A5?
You can delete registry entries and it will not load the driver.
Could you give me the path to the registry entries?
Do you mean
HKEY_LOCAL_MACHINE\Drivers\Builtin\UARTB
which should refer to the UART2 of VF61 SoC?
This path →
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\UARTB]
