I need to disable the LVDS display on the Apalis TK1. How do I do that?
You may simply disable LVDS from user space using XrandR e.g. as done here. However please note that if no HDMI screen is connected/active LXDM resp. lxpanel may have issues due to no display being available at all. However in case of a head less system LXDM and friends should anyway be disabled.
You may reconfigure the kernel as follows:
# CONFIG_TEGRA_LVDS is not set
make menuconfig
Device Drivers > Graphics support >[ ] Enable LVDS panel.
I solved this by adding the following to /etc/X11/xorg.conf
Section "Monitor"
Identifier "LVDS-0"
Option "Ignore"
EndSection
This works for me for now.
Thanks for you help.
Yes, I guess that works as well as it is basically using XrandR behind the scenes as well.
You are very welcome.
