Hi
i am new user of toradex and going to perform this activity as mentioned in question. i am using vf61 board with iris var 1.0. kindly suggest me from where can i get information regarding this.
Hi
Could you quickly let us know which OS you plan to use?
I am using Windows CE & i am going to interface 3x3 matrix keypad with my board…
I did a quick search on internet and found reference which you may want to use:
ADC Library is available here ( WinCE Libraries & Code Samples - VFxx, iMX6, PXA & Tegra modules ) with the documentation and example code.
BTW: we have matrix keypad example but using digital IOs, see here: How to use Matrix Keypad
To know more on how to contact support, please read this article: How to contact the support
Thanks for your support. Actually in the above link ( How to use Matrix Keypad) the keypad has matrix form inputs i.e 8 pins are connected to the board (4 rows + 4 columns). But in my case , i am using keypad that has only one input pin that i connected to the ANALOG_IN1. kindly suggest me an article having one input pin to the board…
Please check this link : http://www.avr-asm-tutorial.net/avr_en/keypad/keyboard.html here will find one example on ADC Input.
I suggest you to take help from some external consultants if you don’t have experience with the embedded hardware or software development.
