Cannot find how to remove unused lockbox in app.torizon.io.
Greetings @Serghey,
Just to clarify what do you mean by “remove unused lockbox”. You can revoke a lockbox so that it is no longer usable, but you can’t “remove” it. Due to how the underlying security framework of our server is, lockboxes can’t be removed as there needs to be a record of them even when revoked.
Hi Jeremias,
Thank you for the reply.
Did not know, that lockbox could not be removed. When we learn offline update procedure some different were created, but now we do not need them.
Just need to look it right. May be it can be done not from our side but from your side and just at once.
Serghey.
Not sure I understand. What exactly are you requesting here?
Remove all revoked (in red) . Please refer below.
I understand now. Currently it’s not possible to remove those from the UI. However, the team does have a request in their backlog that will add the ability to hide these revoked lockboxes in the UI.
Once this feature is available it should help the clutter and organization of lockboxes.
Yes, this is what we need. Will appreciate, if you help to clean it up.
Serghey.
Please keep an eye out for when this feature will be available.
Ok,
Thank you for the explanation.
