How to connect toradex board without FF UART with USB
hello,
I want to connect toradex board with putty.
I use FFUART for gprs modem and I use UART B for telit module so ı could not connect to linux board.
you can say use the IP but I have diffirent subnet Ip so ı cant connect with Ip.
for example;
my Ip : 192.168.1.61
toradex board Ip : 10.61.1.61
in this case ı want to connect via usb ? can ı do this ?
Sure, have a look at the following article on our developer website explaining available USB device mode options:
http://developer.toradex.com/knowledge-base/usb-device-mode-(linux)#NXPFreescale_VybridiMX6_based_Modules
which function am ı use ?
am ı use gser ( Generic serial bulk in/out ) function ?
gser definition in here " The function talks to the Linux-USB generic serial driver"
I use colibri imx6 DL, iris carrier board and have a linux (angstrom )operation system …
