We have a display which is supporting 1024x600 resolution at 43 Hz. What is the corresponding VESA timing should we use through https://developer.toradex.com/knowledge-base/display-driver-registry-settings?
Use following links to extract EDID information of Non-Standard VESA resolution display and configure display registry settings.
Read or Extract EDID information from the Display: http://www.entechtaiwan.com/util/moninfo.shtm
Ex:
” Native/preferred timing… 1024x600p at 43Hz
Modeline… “1024x600” 32.000 1024 1064(H Front porch) 1112(H Sync) 1152(H back porch) 600 613(V Front porch) 616(V Sync) 645(V Back) -hsync -vsync”
