I want to configure LVDS in dual channels with kernel 3.14.28 on the Apalis IMX6Q 2GB IT.
With old kernel the cmdline parameters for this screen was :
video=mxcfb0:dev=ldb,1920x1080M@50,if=RGB24 ldb=spl0
Can anyone help me.
Can anyone help me.
Hi
I will have to change the device tree and adapt the kernel cmdline to contain:
In the device tree the display interface (node mxcfb1) must be configured for 24 pixel mode, and the LVDS Display Bridge (node ldb) must be configured for split-mode, 24bit data-width and the first display-timing must be the one you need.
E.g. something like this:
--- a/arch/arm/boot/dts/imx6qdl-apalis.dtsi
+++ b/arch/arm/boot/dts/imx6qdl-apalis.dtsi
@@ -81,7 +81,7 @@
mxcfb1: fb@0 {
compatible = "fsl,mxc_sdc_fb";
disp_dev = "ldb";
- interface_pix_fmt = "RGB666";
+ interface_pix_fmt = "RGB24";
default_bpp = <16>;
int_clk = <0>;
late_init = <0>;
@@ -1000,13 +1000,13 @@
&ldb {
-// split-mode;
+ split-mode;
// dual-mode;
lvds-channel@0 {
reg = <0>;
fsl,data-mapping = "spwg"; /* "jeida"; */
- fsl,data-width = <18>;
+ fsl,data-width = <24>;
crtc = "ipu2-di1";
primary;
@@ -1030,7 +1030,6 @@
vsync-active = <0>;
pixelclk-active = <0>;
-#endif
/* Standard XGA timing */
timing_xga: 1024x768 {
clock-frequency = <65000000>;
@@ -1060,6 +1059,7 @@
vsync-active = <0>;
+#endif
timing_fullhd: 1920x1080 {
clock-frequency = <138500000>;
hactive = <1920>;
Thank you for your answer
