How to change the ip address of imx7 1gb through programming with snmp protocol
Hi @surya11,
You need to use the newer image as the image that you are using is no longer supported.
You can check the new images from here
Also, you may need to customize your image by adding snmp packages as mentioned on your previous post.
Let me know if you need more help.
