Dear Sir,
We are using TorizonCore with Colibri iMX6DL 512MB.
Please let me know how to change the display resolution.
In case of Yocto, we used to follow Display Output, Resolution and Timings (Linux) | Toradex Developer Center but same is not working in TorizonCore.
I tried similar changes through U-Boot but resolution is default to 600x480
Kindly Help!
Pradeep Pol
Hi @eklavya19
Greetings from toradex community.
Did you configure the display as per our article? if not please refer to the display article. also please let us know the display information.
Hi @ashok.tx,
I have used the available dts file (display-lt161010-overlay.dts) and activated it using
dtconf activate display-lt161010-overlay.dts -c imx6dl-colibri-eval-v3.dtb
and We got the required display resolution of 800x480.
Thanks for the support.
Pradeep Pol
