Hi, I need to change device hostname in my apalis imx8 running torizon core. I test Linux hostname command and It works but when I reboot my device I Lost It.
Best regards
Best regards
Hi @delta,
the hostname
command is effective only until the next reboot. In order to make a permanent change, you need to edit /etc/hostname
, as stated in the manual from hostname (you can run man hostname
on your computer if you’re using Linux):
SET NAME
When called with one argument or with the --file option, the commands set the host name or the NIS/YP do‐
main name. hostname uses the sethostname(2) function, while all of the three domainname, ypdomainname and
nisdomainname use setdomainname(2). Note, that this is effective only until the next reboot. Edit
/etc/hostname for permanent change.
Hiago.
Thanks @hfranco.tx for your answer, I use sudo hostnamectl set-hostname NAME and it works fine.
