How to change Display Resolution at the time of Open Embedded Build IMX7
I want to change the resolution of the display along with associated timings for a 7" capacitive display bought from Toradex with a resolution 800x480.
I am building a image for QT5 using open embedded as detailed in the article
https://developer.toradex.com/knowledge-base/how-to-set-up-qt-creator-to-cross-compile-for-embedded-linux
Host is Ubuntu 8.04LTS and board is Colibri I.MX7D 512MB.
How can I do so before I start the bitbake command?
I am not familiar with that exact CPU module, or which kernel you are using. However, the answer you need is probably here:
https://developer.toradex.com/knowledge-base/display-output-resolution-and-timings-linux#iMX_6ULL_and_iMX_7_based_modules
hi @aparundekar
Yes you can. Modify u-boot sources to suit your needs , create patch and add patch to your layer in yocto. For reference check out these videos.
Another way to modifying the U-Boot variables is to use the U-Boot environment file after creating the Toradex Easy Installer Image.
Best regards, Jaski
Thanks a lot.
I used vidargs in uboot menu and it was done.
I still could not understand how to modify the dts file , compile uboot using open-embedded.
Ajit
You don’t need to change the devicetree file but just uboot environment.
