How to build mcc-kmod?
Where I can find instructions on how to build mcc kernel module? I’m using linux toradex_vf_4.1-next and when I follow the instructions at http://developer.toradex.com/knowledge-base/mqx-on-the-cortex-m4-of-a-colibri-vf61 I got the following error:
open("/dev/mcc", O_RDWR): No such file or directory
Daniel
There’s no need to compile mcc kernel to run MQX on Cortex M4. It’s only necessary install the module using
modprobe mcc
