To successfully add an in-tree kernel module to your Torizon Yocto build, you need to ensure that the module is properly configured, compiled, and included in the final image. Here are some steps to help you troubleshoot and resolve the issue:
Verify Kernel Configuration: Make sure your bbappend file is correctly modifying the kernel configuration. The line
echo "CONFIG_TOUCHSCREEN_HYCON_HY46XX=m" >> ${WORKDIR}/defconfigshould enable the module as a loadable module (m). After runningbitbake, check the.configfile in the build directory to confirm that this configuration is present. -
Check Compilation: Ensure the module is being compiled by inspecting the build logs for any errors related to the module. The module should be compiled into a
.kofile, which is the format for loadable kernel modules. -
Include Module in Image: If the module is compiled but not included in the image, you may need to explicitly add it to the image. You can do this by adding the module to the
IMAGE_INSTALLvariable in your image recipe orlocal.conflike this:IMAGE_INSTALL_append = " hycon-hy46xx"This ensures the module is included in the final image.
Rebuild the Image: After making these changes, rebuild your image using
bitbaketo ensure the module is included. -
Verify on Target: Once the image is deployed to your device, verify that the module is available by using the
modprobecommand to load it andlsmodto check if it is loaded.
By following these steps, you should be able to successfully add and verify the in-tree kernel module in your Torizon Yocto build.
Help to integrate a custom kernel into a Torizon Core Image.
