How do I get the ADV7280 camera board working with Apalis iMX6 Eval Board? [SOLVED]
I’m experiencing two video issues with the iMX6 Apalis Eval Board and the ADV7280-based analogue camera adapter.
  1. pink and green lines
  2. start of frame is moving vertically across the screen
To record the attached video, i used the following command:
gst-launch-1.0 imxv4l2videosrc ! imxvpuenc_h264 ! avimux ! filesink location=adv7280_fcbx10.avi
Same issues with this command:
gst-launch-1.0 imxv4l2videosrc ! autovideosink
dmesg shows:
[ 4639.850915] mxc_v4l2_output v4l2_out.35: Bypass IC.
[ 4639.855890] mxc_v4l2_output v4l2_out.35: Bypass IC.
[ 4640.341705] imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_5 = 0x00000001
[ 4640.393361] imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_5 = 0x00000001
Kind regards
Christian
We have the same problem…
Hardware:
  • Apalis iMX6Q 1GB V1.1A
  • Apalis Evaluation Board V1.1A
  • Analogue Camera Adapter V2.0A (ADV7280-based)
  • Analogue Camera Sony FCB-EX2700P
    Software:
  • BSP: Toradex BSP LinuxImageV2.5
  • Image: angstrom-lxde-image
I too have this problem.
See: https://www.toradex.com/community/questions/4049/analogue-camera-module-ver-20a-with-apalis-imx6-gr.html
Please have a look here.
The two questions report likely the same problem. So I’d like to keep comments and answers together in one thread.
[solved] Patching the driver as described in the other post worked for me. Thank you!
