How can ı detect just plug out the power cable on iris board use colibri imx6 computer on module?
I want to detect just plug out the power cable on iris board use shell script. which gpio will I control ?
when ı detect plug out the power cable ı want to make some job but firstly ı can detect.
thank you so much for replies …
Hi
There is no brown out detection circuit on any of our carrier boards.
So what you want to do is not possible. You would have to add hardware which detects a power interruption and which will signal this on any free GPIO to the module.
Max
hi,
I want to call a custom bash script when colibri shut down or start up or plug out the power cable.
here is my bash script name of initmodem
#! /bin/sh
# /etc/init.d/initmodem
# Some things that run always
touch /home/root/initmodem.txt
# Carry out specific functions when asked to by the system
case "$1" in
  start)
    echo "Starting script initmodem"
    echo "start case ">> /home/root/initmodem.txt
	pon gprs
  stop)
    echo "Stopping script initmodem"
    echo "stop case ">> /home/root/initmodem.txt
	poff gprs
    echo "Usage: /etc/init.d/blah {start|stop}"
    exit 1
esac
exit 0
path of this script “/etc/init.d/initmodem”
I want to start service so ı write this command
> update-rc.d initmodem defaults 91
Now ı plug out the power cable than
plug in system reboot
ı look the initmodem.txt file just write a " start case"
but ı will wait
stop case
start case
this case this is not work.
I try reboot system from console
this time its work perfect.
ı see this lines in initmodem.txt
stop case
start case
how can ı fix this problem ? ı must call “poff gprs” command before shut down or plug out the power cable or restarting any reason …
