Hello! Thank you for providing all the details and code. Let’s walk through the setup and identify what might be causing your fixed SPI values.
1. Device Tree Overlay Validation
Your device tree overlay looks close to correct. Important things to check:
- The SPI bus
ecspi3
is correctly enabled. - The node under
ecspi3
(spidev@0
) usescompatible = "rohm,dh2228fv"
to get spidev devices visible. - Ensure there are no other overlays or device tree fragments conflicting with your pinmux or enabling the same SPI bus differently.
Carefully verify that your overlay is properly built and deployed to the board. Here are steps you can follow:
- Check for the expected SPI device in Linux:
You should seels /dev/spidev*
/dev/spidev2.0
. - Confirm the device tree overlay is applied using:
Or validate it incat /proc/device-tree/chosen/overlays/
/sys/firmware/devicetree/base
2. GPIO and SPI Container Access
Your Docker commands and permissions look mostly correct. A couple of notes:
Ensure the container has access to
/dev/spidev2.0
and/dev/gpiochip6
When running the container, mount the host’s
/dev
directory, or explicitly pass both devices:docker run --rm -it \ --device /dev/gpiochip6 \ --device /dev/spidev2.0 \ -v /dev:/dev \ --device-cgroup-rule='c 254:* rmw' \ <your-image>
Ensure your container’s user is a member of the right groups:
gpio
,spi
, orroot
for testing (SPI permissions)
3. libgpiod Setup in Container
Make sure your Python environment in the container has the libgpiod
library available.
For Debian-based images, the following packages are often required:
"deps": [
"libgpiod2"
"devDeps": [
"libgpiod-dev"
4. Python SPI Usage and Manual Chip Select
A few checks for your code:
- Since you’re controlling CS manually, ensure that you do not let the SPI driver toggle CS itself. This is usually the default on spidev (it expects hardware CS). Because you control CS with GPIO, you must verify that the pinmux is NOT assigning SODIMM 63 to a native SPI CS function, and it is set as a GPIO in the overlay and not driven by the SPI hardware.
Timing
- The timing between toggling CS and performing the SPI transfer is important. Sleeping 10ms before each transfer is usually more than required, but it’s safe for debugging.
Data Format
spi.bits_per_word = 16
means each entry inspiData_Range
is a single transfer of 16 bits (2 bytes). Confirm your slave device expects this format.- If your device expects 8-bit words, use
spi.bits_per_word = 8
Debug SPI Communication
- You’re always receiving
[69, 0, 0, 0]
. This often indicates:- The wiring to the slave is not correct.
- The slave is not selected (CS gating issue).
- SPI mode or speed is mismatched.
- The overlay is not properly setting up the pins for SPI and CS GPIO.
- The device attached to SPI does not respond.
5. General Recommendations
- Double-check the hardware connection (especially MISO, MOSI, SCK, CS).
- Use an oscilloscope or logic analyzer to verify SPI lines toggle as expected.
- Test the SPI bus with a known good slave, or try a loopback test (short MISO and MOSI).
- If possible, try to use the default hardware-controlled CS first, see if it works, and then switch to manual CS if required.
Summary Checklist
- Confirm SPI bus and device tree overlay is loaded (SPI on Torizon).
- Validate GPIO pin SODIMM 63 is configured as a GPIO and not a hardware CS in the device tree (Pin Multiplexing).
- Ensure proper permissions and device nodes are passed into your container.
- Make sure your software setup matches the electrical and logical requirements of the SPI device.
- Check physical connections and logic levels for SPI signals.
If after all these steps you still get only constant values, there is likely a hardware wiring or incorrect CS handling issue.
Please follow the above, and let me know where you get stuck or if results change!
