Dear Toradex community,
when I enable hostapd via hostapd_cli, I get the following error:
hostapd_cli enable
Selected interface 'uap0'
[ 297.502940] mwifiex_sdio mmc1:0001:1: cannot change wiphy params when connected
FAIL
In this case,
- I have to disable the wifi-network like this:
wpa_cli disable_network 0
Selected interface 'mlan0'
[ 2585.909879] mwifiex_sdio mmc1:0001:1: info: successfully disconnected from 7a:ac:b9:04:eb:39: reason code 3
OK
- Enable the hostapd
hostapd_cli enable
OK
- and re-enable the wifi-network again
wpa_cli enable_network 0
OK
Is this normal, or is there a better way to do that?
My environment:
- Viola Plus carrier board
- Yocto-build as follows
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-tdx-linux-gnueabi"
MACHINE = "colibri-imx6ull"
DISTRO = "tdx-none"
DISTRO_VERSION = "5.7.0-devel-20220809070425+build.0"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-toradex-nxp = "HEAD:ee63c90fde9fde0229bff9ac1c5cffe356fc4f41"
meta-freescale = "HEAD:c4347b507c2ba0d7eb3917303f83631244bf5048"
meta-freescale-3rdparty = "HEAD:88773cbb6367496b1a2ddca683afcd352be3cd58"
meta-toradex-tegra = "HEAD:f5753af4a5b9d33f0f474b320a74c2e29a66ec39"
meta-toradex-bsp-common = "HEAD:029a663150449a5e71b84dd4000476754d525c8c"
meta-oe
meta-filesystems
meta-initramfs
meta-networking
meta-multimedia
meta-python
meta-webserver = "HEAD:52cee67833d1975a5bd52e4556c4cd312425a017"
meta-freescale-distro = "HEAD:5d882cdf079b3bde0bd9869ce3ca3db411acbf3b"
meta-checkbox = "HEAD:770ccb49ac3d2a335a9e60da841f732c4885d566"
- wpa_supplicant.service
cat /lib/systemd/system/wpa_supplicant.service
[Unit]
Description=WPA supplicant
Requires=sys-subsystem-net-devices-mlan0.device
After=sys-subsystem-net-devices-mlan0.device
Before=network.target
Wants=network.target
[Service]
Type=dbus
BusName=fi.w1.wpa_supplicant1
ExecStart=/usr/sbin/wpa_supplicant -c /etc/wpa_supplicant.conf -i mlan0 -u
[Install]
WantedBy=multi-user.target
Alias=dbus-fi.w1.wpa_supplicant1.service
- hostapd.service
cat /lib/systemd/system/hostapd.service
[Unit]
Description=Hostapd IEEE 802.11 AP, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator
After=network.target
[Service]
Type=forking
PIDFile=/run/hostapd.pid
ExecStart=/usr/sbin/hostapd /etc/hostapd.conf -P /run/hostapd.pid -B
[Install]
- wpa_supplicant.conf
cat /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
config_methods=push_button
network={
ssid="solveNet-TestRoom"
psk="psk"
- hostapd.conf (only my changed properties)
interface=uap0
ctrl_interface=/var/run/hostapd
ssid=MySSID
country_code=AT
hw_mode=g
channel=2
- mwifiex
[ 16.586764] mwifiex_sdio mmc1:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p197)
[ 16.595019] mwifiex_sdio mmc1:0001:1: driver_version = mwifiex 1.0 (16.68.1.p197)
