HDMI output 1600 x 480 stretched to 1280x720
I have a new HDMI bar display with a resolution of 1600x480. I set the resolution using vidargs on U-Boot but when kernel starts the resolution is set to 1280x720. The images apppear stretched on the display.
What I have to do in order to set the correct resolution on the kernel?
I can’t rebuid the kernel I’m using B2qt precompiled image.
As explained in the following article on our developer network, HDMI really does DDC/EDID to determine the displays timings:
https://developer.toradex.com/knowledge-base/display-output-resolution-and-timings-linux#iMX_6_HDMI_Output
You may try an alternate CEA setting though.
Alternatively, you may recompile the kernel with some hard-coded display settings.
