HD and SD Streams from AR0521 camera
Update: Some time after my previous post the camera froze again. We will get back in contact with the camera vendor.
I will send updates here when we get a new version of the driver that runs more reliably.
@btj2, using the extension should not be a problem here, but it introduces more variables in the test.
As I also experienced the problem in a more controlled environment, I don’t believe your failure was due to the use of the extension.
Bruno
