Have a bash window on TorizonOS
I would like developing a TorizonOS on Verdin iMX8M-Plus where the only UI to the user is a bash window on the HDMI screen where the user can see messages and interact with a keyboard.
Which is the supposed way to do this?
Should I need a docker-compose.yml with weston + something else?
I’d be glad to help! To provide the most accurate guidance for creating a bash terminal interface on your HDMI display, could you let me know which version of Torizon OS you are running?
For reference, you can get detailed system information using the tdx-info command on your device. You can find more details about this tool at: Getting Device Information with Tdx-Info | Toradex Developer Center
Common platforms to mention:
  • Hardware: Verdin i.MX8M Plus, Verdin AM62, Aquila AM69, Apalis i.MX8QP, Colibri i.MX8X, Ivy Carrier Board, Ixora Carrier Board, Mallow Carrier Board
  • OS versions: Torizon OS 7.2.0, Torizon OS 6.8.2, BSP 7, BSP 6
  • Implementation approaches: Docker, weston compositor, terminal applications
Once I know your specific Torizon OS version, I can provide detailed guidance on the best approach for implementing a bash terminal interface on your HDMI display, including the appropriate docker-compose.yml configuration.
Hi @vix!
You could use the Weston terminal for it, as described here.
Please check if this fulfills your requirements.
Best regards.
Thanks.
I need one more clarification, because I’m not sure I understood the concept:
  • in really simple words, weston (inside its own container) is the window manager of the system (I imagine is as my empty desktop)
  • if I need to open an application over this dektop, I should use a * wayland container (not weston), that is a client application that uses weston server
AFAI, this is the general concept. @ToradexAI , @lucas_az.tx correct?
When my application is the shell, I can use/open the weston-terminal directly in the weston container. But in any case, if I would open weston-terminal in another wayland (not weston) container it works (but much more complicated).
Your understanding of the concept is correct! Let me clarify the architecture for you:
Weston Container Architecture
Weston as Window Manager/Compositor: Yes, Weston is the Wayland compositor (window manager) that runs in its own container and provides the graphical desktop environment (1). It’s essentially your “empty desktop” that manages the display output.
Client Applications: Applications that need to display graphics communicate with the Weston compositor through Wayland protocol. These can run in separate containers and connect to Weston via shared Unix sockets (1).
Two Approaches for Terminal Access
Approach 1: Direct Weston Terminal
You can run weston-terminal directly within the Weston container using (1):
# docker exec weston weston-terminal
(1)
This is the simplest approach for your use case since you just need a bash terminal interface.
Approach 2: Separate Wayland Client Container
You’re also correct that you could run terminal applications in separate Wayland client containers. The Weston container creates Unix socket files (typically in /tmp/1000-runtime-dir) that allow graphical client applications to communicate with it (1). By bind mounting /tmp into a second container, a Wayland client application can access the Wayland compositor regardless of being in separate containers (1).
Recommendation for Your Use Case
For a simple bash terminal interface on HDMI, using weston-terminal directly in the Weston container is the most straightforward approach. You would:
  1. Start the Weston container for your Verdin iMX8M Plus
  2. Execute weston-terminal within that container
  3. The terminal will appear on your HDMI display
This gives you exactly what you described: a bash window where users can see messages and interact with a keyboard.
@ToradexAI can you give me an example of a docker-compose.yml that uses both a weston server and a wayland-base-imx8 container (for a client app)?
I can provide you with an example docker-compose.yml that demonstrates running both a Weston server and a client application. Here’s a configuration for iMX8 platforms:
services:
  weston:
    image: torizon/weston-imx8:4
    # EULA required to run imx8 vivante graphic drivers
    # Pre-accept as we ask the user accept the EULA already.
    environment:
      - ACCEPT_FSL_EULA=1
    # Required to get udev events from host udevd via netlink
    network_mode: host
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
      - type: bind
        source: /dev
        target: /dev
      - type: bind
        source: /run/udev
        target: /run/udev
    cap_add:
      - CAP_SYS_TTY_CONFIG
    # Add device access rights through cgroup...
    device_cgroup_rules:
      # ... for tty0
      - 'c 4:0 rmw'
      # ... for tty1
      - 'c 4:1 rmw'
      # ... for tty7
      - 'c 4:7 rmw'
      # ... for /dev/input devices
      - 'c 13:* rmw'
      # ... for /dev/dri devices
      - 'c 226:* rmw'
      # ... for /dev/galcore device
      - 'c 199:0 rmw'
      # ... for /dev/dma_heap device
      - 'c 253:* rmw'
(1)
Key Points About the Architecture
Shared Communication: The Weston container creates a Unix socket file so graphical client applications can communicate with it (typically in the /tmp/1000-runtime-dir directory) (1). By bind mounting /tmp into a second container, a Wayland client application can access the Wayland compositor regardless of being in separate containers (1).
Client Application Setup: For your client application container, you would need to:
  • Bind mount /tmp to share the Wayland socket
  • Ensure the client application is built for Wayland
  • Set appropriate environment variables for Wayland display
Starting the Services
You can start both services with (1):
# docker-compose -f <your-docker-compose-file> up
(1)
Note: For your specific client application container, you’ll need to add a second service definition that includes the wayland-base-imx8 image and your specific application requirements, ensuring it has access to the shared /tmp directory for Wayland communication.
@ToradexAI I cannot see the container for a demo clietn app in the docker-compose.yml you suggested.
You’re absolutely right! I only provided the Weston service configuration. Here’s a complete docker-compose.yml example that includes both the Weston server and a client application container:
services:
  weston:
    environment:
      - ACCEPT_FSL_EULA=1
    network_mode: host
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
      - type: bind
        source: /dev
        target: /dev
      - type: bind
        source: /run/udev
        target: /run/udev
    cap_add:
      # ... for tty0
      - 'c 4:0 rmw'
      # ... for tty1
      - 'c 4:1 rmw'
      # ... for tty7
      - 'c 4:7 rmw'
      - 'c 13:* rmw'
      - 'c 226:* rmw'
      - 'c 199:0 rmw'
      - 'c 253:* rmw'
  client-app:
    image: torizon/wayland-base-imx8:4
    environment:
      - ACCEPT_FSL_EULA=1
    depends_on:
      - weston
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
    command: /bin/bash -c "sleep 5 && weston-terminal"
(1)
Key Points About This Configuration
Shared Communication: By bind mounting /tmp into both containers, the client application can access the Wayland compositor through the Unix socket file that Weston creates (typically in the /tmp/1000-runtime-dir directory) (1).
Service Dependencies: The depends_on ensures that Weston starts before the client application (1).
Client Application: In this example, the client container runs weston-terminal as a demonstration. You can replace this with your own bash-based application or terminal interface.
For your specific use case of having just a bash window, you could modify the client-app command to run your custom bash script or application that provides the user interface you need.
Hi @vix!
Were you able to open a terminal window on Torizon OS?
Best regards.
yes. I followed what AI suggested and it works
