Good morning.
We need to interface a Capacitive touch interface with our Colibri VF61 .We are using GT9271 Chipset (belongs to Goodix driver) .how to use this driver in our device
Thank you .
Good morning.
Thank you .
hi jojo
which bsp version and carrier board are you using? how do you want to connect your GT9271 CPT touch to colibri vf61.
what is your device?
We are using Colibri_VF_LinuxImage V2.6 version and custom carrier board. CPT touch is connect with colibri vf61 by using I2c interface
Hi
It looks like the kernel used for Colibri VF does in fact contain a driver for your touchscreen.
You would have to configure the kernel to include the relevant config and adapt the device tree to configure said driver correctly, and then rebuild and deploy kernel/modules/device tree.
Have a look at the commit which added the driver and its documentation.
Max
hi
when Goodix touch driver used in our board ,shows this error
root@colibri-vf:~# dmesg | grep Goodix
[ 1.290321] Goodix-TS 0-0014: i2c test failed attempt 1: -11
[ 1.327106] Goodix-TS 0-0014: i2c test failed attempt 2: -11
[ 1.367035] Goodix-TS 0-0014: I2C communication failure: -11
[ 1.379743] Goodix-TS: probe of 0-0014 failed with error -11
my colibri -eval-v3.dtsi like this
&i2c0 {
clock-frequency = <400000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c0>;
gt9271@14 {
compatible = "goodix,gt9271";
reg = <0x14>;
interrupt-parent = <&gpio0>;
interrupts = <15 IRQ_TYPE_EDGE_FALLING>;
irq-gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
reset-gpios =<&gpio0 16 GPIO_ACTIVE_LOW>;
//reset = <&lcd_reset>;
//status = "okay";
can you help me to find a solution
hi
Could you provide the details (images) about your hardware connection of the GT9271 to your board? Please name to which SODIMM Pin of Module which signal (i2c, reset, interrupt) is connected?
Additionally can you check using i2cdetect
if the i2c connection to the cpt touch is working?
hi Jaski
we use Colibri vf61 custom board with Linux angstrom distribution for development purpose. In that case include a 7 " capacitive touch 800x480 densitron display with goodix touch driver( Goodix touchscreen driver(GT9271) with densitron display(DMT070WVNLCMI)). But we can’t successfully install goodix driver in our board.
when booting we see this message.
[ 1.806835] Goodix-TS 0-0014: i2c test failed attempt 1: -6
[ 1.846960] Goodix-TS 0-0014: i2c test failed attempt 2: -6
[ 1.886839] Goodix-TS 0-0014: I2C communication failure: -6
root@colibri-vf:~# dmesg | grep i2c
[ 0.143166] i2c i2c-0: IMX I2C adapter registered
[ 0.143301] i2c i2c-0: using dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 1.930222] i2c /dev entries driver
also our device shows these data too
root@colibri-vf:~# i2cdetect -y 0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- 14 -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@colibri-vf:~# modinfo goodix
filename: /lib/modules/4.4.121-dirty/kernel/drivers/input/touchscreen/goodix.ko
license: GPL v2
description: Goodix touchscreen driver
author: Bastien Nocera
author: Benjamin Tissoires
srcversion: 14EC9CF3D1F29A86BF0A7F7
alias: i2c:GDIX1001:00
alias: of:N*T*Cgoodix,gt967*
alias: of:N*T*Cgoodix,gt928*
alias: of:N*T*Cgoodix,gt9271*
alias: of:N*T*Cgoodix,gt927*
alias: of:N*T*Cgoodix,gt912*
alias: of:N*T*Cgoodix,gt9110*
alias: of:N*T*Cgoodix,gt911*
depends:
intree: Y
vermagic: 4.4.121-dirty mod_unload modversions ARMv7 p2v8
root@colibri-vf:~# ls /sys/bus/i2c/devices/
0-0014 0-0068 i2c-0
NOTE : attached some configuration file with circuit for checking purpose link text
Hi
Looking through your device-tree files I found the following inconsistencies:
vf-colibri-eval-v3.dtsi, ln 226
pinctrl_gpiotouch: touchgpios {
fsl,pins = <
VF610_PAD_PTA15__GPIO_25 0x6f
VF610_PAD_PTA16__GPIO_26 0x4f
VF610_PAD_PTB8__GPIO_30 0x6f
VF610_PAD_PTB1__GPIO_23 0x4f
vf-colibri-eval-v3.dtsi, ln 147
touch:
gt9271@14 {
reg = <0x14>;
reset = <&gpio0 16 GPIO_ACTIVE_LOW>;
You use gpios which get muxed by ‘pinctrl_gpiotouch: touchgpios’ but you
do not add that muxing to the gt9271@14 node.
You should add two addtional properties:
pinctrl-0 = <&pinctrl_gpiotouch>;
Note that the goddix driver has no code to handle a reset pin. Thus the pin
will be muxed to gpio input and stays that way. Since you have an external
pullup reset will be deasserted and the chip should work.
&esdhc1 {
pinctrl-0 = <&pinctrl_esdhc1>;
bus-width = <4>;
This node configures the SD card driver to use pinctrl_esdhc1. This pinctrl
uses the same pins that you use for IRQ / RESET for your touchcontroller.
I guess that your HW does not have any SD card slot, so you can set
status = “disabled”
in this node.
Max
hi max
i change my configuration file like above.but still problem is not solved yet.
these are the response while send these commands
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
0-0014 0-0068 i2c-0
root@colibri-vf:~# ls -l /dev/i2c-0
crw------- 1 root root 89, 0 Oct 4 08:17 /dev/i2c-0
filename: /lib/modules/4.4.121-dirty/kernel/drivers/input/touchscreen/gooo
license: GPL v2
depends:
intree: Y
[ 0.142984] i2c i2c-0: IMX I2C adapter registered
[ 0.143125] i2c i2c-0: using dma0chan0 (tx) and dma0chan1 (rx) for DMA transs
[ 1.349909] i2c /dev entries driver
any other configuration required for this?
Hi
It looks like the issue is worse now. Could you share your device tree files, please? Thanks.
hi jaski,
Thank you for your time,
here I attach all device tree file with this ,link text
and also attached some extra configuration fileslink text
note: location of the file are included in to name.
when send this command i can able see only I2C pins not any IRQ or RESET pins(filtered)
root@colibri-vf:~# cat /sys/kernel/debug/pinctrl/pinctrl-handles
Requested pin control handlers their pinmux maps:
device: 40066000.i2c current state: default
state: default
type: MUX_GROUP controller 40048000.iomuxc group: i2c0grp (9) function: vf610-colibri (0)
type: CONFIGS_PIN controller 40048000.iomuxc pin VF610_PAD_PTB14 (36)config 000037ff
type: CONFIGS_PIN controller 40048000.iomuxc pin VF610_PAD_PTB15 (37)config 000037ff
Thankyou
hi
Thanks for the files. Could you just send the files with the changes asked by max.tx and show clearly what did you change? Thanks.
hi max
good morning.
here attached all file that what we are changed.
all device tree file with this link. link text and
some extra configuration files link link text
changes done are in short
**in file vfxxx.dtsi**
i2c0: i2c@40066000 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "fsl,vf610-i2c";
reg = <0x40066000 0x1000>;
interrupts = <71 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks VF610_CLK_I2C0>;
clock-names = "ipg";
dmas = <&edma0 0 50>,
<&edma0 0 51>;
dma-names = "rx","tx";
*status = "okay";*
In file vf-colibri-eval-v3.dtsi
&esdhc1 {
bus-width = <4>;
status = "disabled";
&i2c0 {
touch: gt9271@14 {
reg = <0x14>;
reset-gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
&iomuxc {
vf610-colibri {
fsl,pins = <
*VF610_PAD_PTA25__GPIO_15 0x31f1
VF610_PAD_PTA26__GPIO_16 0x31f2*
In fille vf-colibri.dtsi
&esdhc1 {
bus-width = <4>;
cd-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
disable-wp;
*status = "disabled";*
&i2c0 {
*status = "okay";*
&can0 {
*//pinctrl-0 = <&pinctrl_flexcan0>;
&iomuxc {
pinctrl-0 = <&pinctrl_hog_0 &pinctrl_hog_1>;
vf610-colibri {
pinctrl_flexcan1: can1grp {
fsl,pins = <
*//VF610_PAD_PTB14__CAN0_RX 0x31F1
//VF610_PAD_PTB15__CAN0_TX 0x31F2*
pinctrl_esdhc1: esdhc1grp {
fsl,pins = <
VF610_PAD_PTA24__ESDHC1_CLK 0x31ef
//VF610_PAD_PTA25__ESDHC1_CMD 0x31ef
//VF610_PAD_PTA26__ESDHC1_DAT0 0x31ef
VF610_PAD_PTA27__ESDHC1_DAT1 0x31ef
VF610_PAD_PTA28__ESDHC1_DATA2 0x31ef
VF610_PAD_PTA29__ESDHC1_DAT3 0x31ef
VF610_PAD_PTB20__GPIO_42 0x219d
Also changes done in other file like
colibri_vf_defconfig file in location linux_toradex/arch/arm/configs/
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
CONFIG_TOUCHSCREEN_FUSION_F0710A=m
CONFIG_TOUCHSCREEN_WM97XX=y
CONFIG_TOUCHSCREEN_GOODIX=m
.config file in location linux_toradex/
CONFIG_TOUCHSCREEN_PROPERTIES=y
Kconfig file in location linux_toradex/drivers/input/touchscreen/
config TOUCHSCREEN_GOODIX
tristate "Goodix I2C touchscreen"
depends on I2C
default y
help
Say Y here if you have the Goodix touchscreen (such as one
installed in Onda v975w tablets) connected to your
system. It also supports 5-finger chip models, which can be
found on ARM tablets, like Wexler TAB7200 and MSI Primo73.
If unsure, say N.
To compile this driver as a module, choose M here: the
module will be called goodix.
Thankyou
Can you also attach the complete kernel debug output? You can save it to a file using dmesg > dmesg.txt
and then attach that file to this thread.
hi
We are done a small change in our circuit.Now Interrupt pin are in pull down state because we are use 0x5d(0xBA/0xBB) as address and this .
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – 5d – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
[ 3.044097] Goodix-TS 0-005d: read version failed: -6
[ 3.058165] Goodix-TS 0-005d: Read version failed.
filename: /lib/modules/4.4.21-dirty/kernel/drivers/input/touchscreen/goodo
license: GPL v2
alias: of:NTCgoodix,gt967*
alias: of:NTCgoodix,gt928*
alias: of:NTCgoodix,gt9271*
alias: of:NTCgoodix,gt927*
alias: of:NTCgoodix,gt912*
alias: of:NTCgoodix,gt9110*
alias: of:NTCgoodix,gt911*
depends:
intree: Y
vermagic: 4.4.21-dirty mod_unload modversions ARMv7 p2v8
our kernel file are attached to this link text
and dmesg response are here link text
hi
any updates
hello, at this point, it is very difficult for us to help you without having the hardware. Please check if the i2c communication with the goodix at startup of linux is working correctly using an oscilloscope and contact the supplier of this cpt touch for help.
Hi
Let me inform you after check it
thankyou,
Hi everyone,
At last my touch driver gives a positive response.When I touch the display that response well, but after a 3 or 4 touch it not response as required. Because ‘goodix_i2c_read’ not success then touch is not working. And also it goto an unknown state. when I give the manual reset to the driver(short RST pin and GND), then it goes to the normal state. Again that work as same that mentioned above.
Please check the file that I attached with this mail.
in my touch circuit, SDA, SCL, RST are pullup with 4,7k to 3.3v and INT are not pulled up.
gt9271@14 {
reg = <0x14>;
goodix,irq-gpios = <&gpio0 15 0>;
goodix,reset-gpios = <&gpio0 16 0>;
goodix,panel-coords = <0 0 479 799>;
goodix,display-coords = <0 0 479 799>;
goodix,i2c-pull-up;
goodix,product-id ="9271";
goodix,have-touch-key;
skip-firmware-request;
reset-delay-us=<10000>;
fsl,pins = <
VF610_PAD_PTA25__GPIO_15 0x22ed//0x2c2e
VF610_PAD_PTA26__GPIO_16 0x398d
when touch isn’t working
[ 49.145897] Goodix-TS 0-0014: I2C transfer error: -11
[ 49.151066] Goodix-TS 0-0014: I2C write end_cmd error
[ 49.156193] Goodix-TS 0-0014: Goodix return -11,Register :814e Count : 747 Result 142
[ 49.163920] Goodix-TS 0-0014: I2C transfer error: -11
[ 49.169074] Goodix-TS 0-0014: I2C write end_cmd error
[ 49.180877] Goodix-TS 0-0014: Goodix return -11,Register :814e Count : 748 Result 142
when touch gives proper response
[ 66.555174] Goodix-TS 0-0014: Goodix return 2,Register :814e Count : 773 Result 0
[ 66.563403] Goodix-TS 0-0014: Goodix return 2,Register :814e Count : 774 Result 0
[ 66.572463] Goodix-TS 0-0014: Goodix return 2,Register :814e Count : 775 Result 129
[ 66.580862] Goodix-TS 0-0014: Goodix return 2,Register :814e Count : 776 Result 0
[ 66.589973] Goodix-TS 0-0014: Goodix return 2,Register :814e Count : 777 Result 128
These response are depend on 'goodix_i2c_read() in goodix.c
please check goodix.c file and vf-colibri-eval-v3.dtsi file .link text
I think my reset PIN are not worked as properly.
Please give me any suggestion
thank you.
