i currently try to get gstreamer working with the V2.6 Image. My V2.4 Image worked flawless without X11, but when building a modified console image with the following lines in local.conf:
DISTRO_FEATURES_remove = "x11 wayland"
PACKAGECONFIG_remove_pn-gstreamer1.0-plugins-good = " gdk-pixbuf "
and added packages within oe-core/stuff/meta-toradex/recepies/images/console-trdx-image.bb:
GSTREAMER = " \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-imx \
gst1.0-fsl-plugin \
IMAGE_INSTALL += " \
angstrom-packagegroup-boot \
packagegroup-basic \
udev-extra-rules \
${CONMANPKGS} \
${ROOTFS_PKGMANAGE_PKGS} \
timestamp-service \
packagegroup-base-extended \
eglinfo-fb \
tslib-conf \
tslib-tests \
tslib-calibrate \
${GSTREAMER} \
gstreamer hangs with the following output:
root@apalis-imx6:~# gst-launch-1.0 tvsrc ! imxv4l2sink
[ 125.844070] ERROR: unrecognized std! ffffff (PAL=ff, NTSC=b000
[ 125.849940] ERROR: unrecognized std! ffffff (PAL=ff, NTSC=b000
[INFO] Product Info: i.MX6Q/D/S
display(/dev/fb0) resolution is (800x600).
(gst-plugin-scanner:660): GLib-GObject-WARNING **: cannot register existing type 'GstImxCompositorPad'
(gst-plugin-scanner:660): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
As you can see i already added the solution mentioned in this thread:
sadly this didn’t make a difference.
Is there something else to take care of?
Thank you very much,
Moritz Wagner
