I try to run the multiple container sample with Grafana on a iMX6DL.
I startet with the Torizon image containing evaluation containers. Then i delete all exect the portainer container.
When I start the Grafana sample everything works expect the local display!!
It is possible to show Grafana on local video output, in addition to having it served over a network interface. To make this possible, we bring-up a Weston container and a Chromium container in kiosk mode. This is an optional part of the demo that uses 2 extra containers and an extra YAML (.yml) file. You can easily remove it if you want.
So, to visualize Grafana on a local video output, you must have Weston (and kiosk) running, and it’s not in your case.
I’ll try to reproduce this issue here locally, and I’ll provide feedback later.
I saw that you opened another Thread for the Torizon release issue.
I hope you have it now cleared. The best way to keep tracking new releases is by the CI feed on Toradex Easy Installer directly.
Then, going back to the Grafana issue, it appears that your problem is now solved with the latest Torizon build, right?
And about the Kiost and Weston, I’ll report it internally to check what is happening.
It is just a matter of time, after I entered login credentials. Than there comes a lot of out of emmory exception, and the module freeze and need a reboot.
I guess there is not enough power to run a browser on it
