GPIO Pull up seems not work under Eboot on Colibri iMX7
Dear Support Team,
Our platform is Colibri iMX7S and Colibri Eva Board, with Toradex WinCE BSP image V1.2 version installed, and now we are testing initializing some gpio pins as input and pull up/up100k under eboot phase according to this developer articles, here below is a example of how we set under eboot, have tried SODIMM 133/43/45/37/29, but all failed to get pulling up work, could you help check on this?
>set gpio gpio.bootconf= "[gpio_58] altfn=-1 dir=in outmode=std pull=up"
>set gpio
gpio.bootconf (Boot GPIO settings. Do not remove default config. (Max 1536 chars)):
'[gpio_6] altfn=-1 dir=in outmode=std pull=up'
>save gpio
Finding configblock...
Writing 5 sector(s) of bootargs data from sector 1792.
Thanks and Best Regards
Simon
Dear @hai.tx
The iMX7 does not support the outmode property, therefore the parser stops at this point.
The following configuration is working just fine:
>set gpio.bootconf "[gpio_58] altfn=-1 dir=in pull=up"
>set gpio
'[gpio_58] altfn=-1 dir=in pull=up'
>save gpio
Regards, Andy
Dear Andy,
Thanks a lot, it just work fine as you mentioned!
